FME Server 2013/2014 on same server
  • Oct 10, 2013 3:41 PM UTC
  • 54 views
sigtill
Forum|alt.badge.img+25
Have anyone tried to have both FME Server 2013 and FME Server 2014 on the same server? Since they both contain a webserver etc I suspect it will not work?
  • Oct 11, 2013 9:31 AM UTC
I believe it should be possible (although I've never tried). But you'll most probably either have to configure Tomcat differently for the two versions so that they run on different ports, or configure two Tomcats so they don't use the same ports (see here: http://stackoverflow.com/questions/4678077/can-i-run-two-tomcats-on-the-same-machine)
David
  • Oct 11, 2013 2:54 PM UTC
Please post feedback if this works. I'm interrested in trying this configuration eventually.
sigtill
  • Oct 14, 2013 6:20 AM UTC
Thank for all the replies.
