Error Opening Path Reader on folder
vxn43
Forum|alt.badge.img+18
I have published a workspace to FME Flow. When I run it in FME Flow, I get this error in the log file:
Path Reader: Error opening the PATH Reader on folder '\\\\myservername\\T_DFshared\\FME Workflow\\All Reports to Folder5'. Could not find folder.
I checked and the server where the folder resides can communicate with the server that FME Flow is installed on.
The folder does indeed exist and has the files used in the workspace in it.
The workspace published from FME Form starts with a Directory and Pathnames Reader and runs with no errors in FME Form.
Could this error be caused by the spaces in the folder names in the UNC path shown above or could something else be causing this error?
Best answer by hkingsbury
Its quite possible that whilst the machines are allowed to 'talk' the account running FME Flow does not have access to that folder. By default the account that runs FME is a local account on the machine its installed on.
You may need to change that to a network level account and set the appropriate permissions
https://docs.safe.com/fme/html/FME-Flow/AdminGuide/Running_System_Services_Under_Different_Accounts.htm
hkingsbury
Forum|alt.badge.img+55
  • October 19, 2023
carlovanopstal
I had this same problem today, hoped this tread had the answer. But the problem for me was that I used an user parameter setting the file in my workspace that I uploaded. But in the featurereader that tries to read out the pathfile should have the fme flow parameter FME_DATA_REPOSITORY to read out the file location that you are uploading the file to on fme flow. This fixed the problem and the reader could read out the file. Hope this will help someone :)
