Can Azure Blob Storage be used for the FME Server System Share (i.e. in a fault tolerant configuration)?
  • Feb 13, 2023 12:04 PM UTC
  • 80 views
john_gis4
Forum|alt.badge.img+13
I have previously successfully configured FME Server with an Azure File Share as the System Share using a UNC path, but have not tried it with blob storage.
Is this supported? If, so how do I configure it?
hkingsbury
Forum|alt.badge.img+73
  • Feb 13, 2023 7:29 PM UTC
I might be barking up the wrong tree here, but can you map blob storage to a drive in windows? Then you could just use that drive
