Hi all,
​I recently converted data in fme from dgn to osgb.
I then published to postgres table. I can see all the attributes including the shape column. I can see numbers and data in each field and each row.
The weird part of this now is, I go to Arcgis Pro and try to view data. Majority of dataset 1000 records work fine but there is like 50 rows which when I click zoom in, it does not have the polyline to display even though all the attributes have been generated including shape column.
I checked FME inspector and everything works fine
I tried in geodatabase it works fine but just issue is with postgis.
Any idea on what this issue could be would be huge help. I also did not generate srid for postgres if it helps.​
Hi @cardiofaz​ ,
Just to confirm, is this a PostGIS table or an SDE on Postgresql? Additionally, if you read the table into FME and pass the features through a GeometryFilter (filtering for line geometry), do all of the features have line geometry or are those same 50 unfiltered?
Sorry for delay getting back but this has worked. Thanks for this seems to be way to detect this. Not yet sure root cause but at least it gives me a start to identify the issue.,
