Why is InlineQuerier not output ?
  • Nov 18, 2021 11:08 AM UTC
  • 5 replies
  • 72 views
screenkHi all,
InlineQuerier doesn't give the last two outputs ?
Best answer by ebygomm
Query script of last output. So, alt_interval_id and polygon_id is like this ;
1112
Because nothing matches the query? In your example posted I can't spot any that should be a match
  • Nov 18, 2021 11:12 AM UTC
1112
Forum|alt.badge.img+54
  • Nov 18, 2021 11:34 AM UTC
1112
  • Nov 18, 2021 12:03 PM UTC
Hi @ebygomm​
Result of other output that is works like this; 333Same query;
22
2232234The same process and it matched but when I use polygon_id and alt_interval_id, it does not work.
  • Nov 18, 2021 1:45 PM UTC
Hi @ebygomm​
22
Same process but different data. That data does match. Which polygon_id are you expecting to match 1.2.1.1.3.5.8.8.1 , because in your screenshot there is not one that matches?
  • Nov 19, 2021 6:30 AM UTC
I understood. Thanks for answer @ebygomm​
