Hello,
I know this is weird but somehow I cannot find the Google API key that I got but I do have it stored in the workbench file for years now, in the Geocoder transformer.
Any idea how/if I could retrieve the API Key somehow? Many thanks
Hello,
Best answer by nielsgerrits
One way to retrieve this:
Important, do not forget to uncheck the Log Debug box after you're done as it will drive you nuts when you don't need it. I believe it will affect performance as well.
