Unable to find coordinate system in gml.
  • Oct 5, 2018 2:54 PM UTC
  • 78 views
i'm unable to read coordinate system for some gml files using inspector.
srs is also mentioned in the gml file(urn:ogc:def:crs,crs:EPSG::2180,crs:PL-KRON86-NH) but the inspector is unable to read the projection.What could be the reason.
mark2atsafe
Forum|alt.badge.img+59
It could possibly be an encoding issue. perhaps open the file in a text editor like Notepad++ to make sure the encoding for the file matches what the header reports.
Otherwise, is there a difference between this srs and in files that FME can read? If you can share a file (even if it's only got one or two features in it) that would help us to diagnose the problem.
