Transpose Column to rows
  • November 18, 2022
  • 766 views
abnan0001
Forum|alt.badge.img+7
Hello Everyone..
I have an query regarding transpose for the attribute
one feature elements are 25 as you can see in ID coumns ..
Now my question is how can i transpose the column names to rows and their inforation related to the field..
Please find the attached screenshot with the FME template with sample dataScreenshotsPlease provide how can i fix the issue
Thank You
Best answer by ebygomm
abnan0001 wrote:
Thanks for the reply
I did the above said but i cant see the results as i wanted
Any suggestions or screenshot
You need to expose the attributes, if you are running with FeatureCaching on you should be able to import them in the AttributeExposer from the cache
Forum|alt.badge.img+35
  • November 18, 2022
If you set up your AttributeCreator like this
imageYou will create new attributes named as per the field name, you will then need to expose the attributes and aggregate with a group by of id making sure Accumulation mode is set to Merge Incoming Attributes
abnan0001
  • November 18, 2022
  • November 18, 2022
abnan0001
  • November 18, 2022
Thank You so much
Got it
