Skp to CityGML
  • Apr 23, 2021 2:04 PM UTC
  • 246 views
Hello. I'm trying to convert Sketchup files to CityGML, i've been following this tutorial: https://www.youtube.com/watch?v=1_eHzACY_RA
I'm very new to FME and CityGML in general, butI've managed to convert Shapefiles to CityGML using a similar workflow.
The skp files does not contain any attributes, and only consists of polygons.
I run the sketchup file through a AttributeCreator to create a gml_id -> CityGMLGeometrySetter (od2MultiSurface) -> CityGML Writer (Buildings - Automatic User Attributes):
If I inspect the CityGMLGeometrySetter I can see the 3D models in the Graphics tab, but it dissapears in the Writer.
Am I doing something obviosly wrong? Why is the geometry not being loaded in the CityGML writer?
Any help or pointers to tutorials explaining some basics that I might be missing is appreciated. I can also upload my workspace and files if that helps.
Robin
itsmatt
Forum|alt.badge.img+48
  • Apr 27, 2021 7:53 AM UTC
Hi @robinosc​  - take a look at the FME Log file, there should be warning messages about why the features are not getting written to CityGML.
You might need to use a FaceReplacer to convert the polygons into surfaces
  • Apr 27, 2021 5:36 PM UTC
Thank you for the reply. I had to swtich from lod2mulitsurface to lod2geometry. Also, I had skipped Deaggregator, which caused issues.
  • Apr 28, 2021 7:13 AM UTC
The files seems to lose their projection when writing the CityGML. When I load the skp (or collada file) directly and set the projection their position is correct, but the CityGML from FME is in the wrong position. I set the projection of the CityGML using a Reprojector from XY-in to EPSG.
Any ideas?
