Select data from one table based on a filed from another table
  • Jun 12, 2023 7:21 PM UTC
  • 107 views
psprague
Forum|alt.badge.img+4
I have two tables. One is a large ODBC table in which I only want to extract the data when the modification date is greater than the last date of another table.
The SQL for what I want to achieve is simple ; SELECT * FROM table1
WHERE modwhen > (SELECT MAX(modwhen1) FROM table2);
Any help is appreciated.
Thank you,
  • Jun 12, 2023 8:23 PM UTC
A FeatureReader with a corresponding Where-clause would be able to accomplish this. An alternative would be to use the SQLExecutor.
psprague
  • Jun 13, 2023 1:11 PM UTC
What would be the syntax for the second table in the reader of table1? Table1 is an ODBC connection while table2 is a csv. ( 2 readers) . I am able to do it using the InlineQuerier with the following syntax SELECT l1.* from "lwLast" s1, "lwoffs" l1 WHERE l1.modwhen > s1.modwhen1, but I'd really like not to have to process the entire lwoffs table.
