Rounder values
mr_fme
Forum|alt.badge.img+8
hi,
how to round values, for example: 5.1 = 6, 7.8 = 8 and so on...
Thank´s
Best answer by geomancer
Use an AttributeRounder, with parameters Decimal Places: 0, Round-off Direction: Up.
 AttributeRounder
geomancer
Forum|alt.badge.img+47
  • May 24, 2023
 AttributeRounder
mr_fme
  • May 24, 2023
Thank´s
  • May 25, 2023
You could also use the following function embedded into e.g. an AttributeManager:
@ceil(@Value(my_attribute_to_round_up))
@ceil() is documented here:
https://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Transformers/!Transformer_Parameters/math_functions.htm
