Reading in a csv file but its merging the attributes into a single attribute instead of delimiting. Is there a way to fix this?
  • Jan 13, 2021 5:36 AM UTC
  • 112 views
I'm new to fme and wondering if I'm doing something wrong? I've tried setting the deliminiter to auto and tried other alterations but no success. There are no issues when I read in other csv files but with this particular file its causing this issue.
Any help would be great!
caracadrian
Forum|alt.badge.img+23
  • Jan 13, 2021 7:33 AM UTC
When you add the CSV reader you first click on the Parameters button so it reads the file and maps the attributes.
It is preferable to have a Header in your first rowAdding CSV reader
bertmeskens
Can you share a part of the CSV? If your delimiter is also used in the values, it could become very messy when using auto. Usually the parameters should give you enough control to fix this.
  • Jan 14, 2021 12:52 AM UTC
This worked! I think I was trying to alter the parameters after the reader had already been added which wasn't working but when I did it when I added the reader it worked. Thanks!
  • Jan 14, 2021 12:53 AM UTC
thanks for your suggestion! It was the auto parameter that caused it, it worked when I altered the parameters while adding the reader. Thanks for your help
