Raster - Force RGB - how can you go about transferring a colormap/palette to turn say a single band raster into a RGB equivalent, coloured by the palette?
  • November 10, 2020
  • 51 views
oliver.morris
Forum|alt.badge.img+12
thank you for your help in advanced.
In ArcMap it is possible to export out a raster based on its currentl styling:
https://pro.arcgis.com/en/pro-app/help/data/imagery/export-or-convert-raster-datasets.htm
Force RGB
Check the Force RGB check box to export the output raster as a three-band RGB raster dataset with the current renderer.
Additionally, while exporting to formats such as TIFF, JP2, PNG, and MRF that support alpha bands, you can use this option to export the data as a four-band raster dataset with an alpha band to preserve the transparency settings of the original data.
Is this possible in FME?
Thank you
Oliver
Best answer by virtualcitymatt
I think​ you want to use the RasterPaltteResolver. This should do what you're after, or at least give a starting point
virtualcitymatt
Forum|alt.badge.img+35
  • November 10, 2020
oliver.morris
  • November 11, 2020
thank you @virtualcitymatt​ will give that a go.
