Python Error - FME Server | Urgent Issue
  • Jan 11, 2021 11:05 PM UTC
  • 26 views
dataninja
Hi everything, I encounter the following error while running PythonCaller on FME Server. Does anyone know how I can fix it? Thanks a lot in advance!
MicrosoftTeams-imageMicrosoftTeams-image (1)
  • Jan 12, 2021 8:50 AM UTC
The error message says "It seems that scikit-learn has not been built correctly", I'd probably start there.
Did you build the scikit modules on the same platform (OS) as FME Cloud?
