problem with ZipExtractor then PythonCaller
I use ZipExtractor to unziped a file, then put it in a folder, but when I go to use PythonCaller to read the files from the folder, it still hasn't finished unzipping all the files.
How do I make it use the next task only when the previous task has finished?
Thank you
nielsgerrits
Forum|alt.badge.img+54
Just to be sure, you do know FME Readers can read in ziparchives right?
When you place a FeatureHolder downstream the ZipExtractor, it will wait until all features have arrived before realeasing any.
  • October 13, 2022
I already tried with FeatureHolder, but when I put it in front of zipExtractor, it doesn't unzip the files..
