Passing dynamic values to shutdown script
  • Nov 6, 2023 1:39 PM UTC
  • 7 replies
  • 232 views
so_much_more
I try to find out how i pass attribute values assigned during runtime to the shutdown script.
I want to pass values of total features read and written from the feature reader\\writer.
I have tried to create private parameters and set the values in runtime with the attribute manager. But the values are <null> / not set when i fetch them in my python script
imageimageThis is the value I am tying to set my private parameter as.
I feel somehow this is the wrong way to do it? What other ways can I set dynamic values that I can use in my shutdown script for logging.
  • Nov 6, 2023 1:59 PM UTC
It's not possible to change parameter values once the workspace has started. Also, unfortunately there is no obvious mechanism for transferring attribute values from the running workspace to the shutdown script. The easiest is to use a PythonCaller in your workspace to set a global variable, then retrieve it in the shutdown script.
so_much_more
  • Nov 6, 2023 2:21 PM UTC
I see, thank you for the help I will give that a go
__alex__
Forum|alt.badge.img+5
  • Jul 11, 2025 12:50 PM UTC
Thanks David ( ​@david_r )!
quick example for those who were as confused as I was at first:
__alex__
  • Jul 11, 2025 12:53 PM UTC
import fme
from fme import BaseTransformer
import fmeobjects
def FeatureProcessor(feature):
    ''' tried this first : not worked
    # global _x
    # _x = "fantastic"
    # this guy:
fme.macroValues['_x'] = 'Hello from PythonCaller'
  • Jul 11, 2025 12:59 PM UTC
import fme
import fmeobjects
    # global _x
    # _x = "fantastic"
    # this guy:
Does that work? If it does, it might break in future versions, as it’s unintended usage. You should never assign anything to fme.macroValues.
The solution is to declare a global variable in the PythonCaller, then reference it in the shutdown script. That means you’ll need to declare it with e.g. global x in both places.
  • Jul 11, 2025 8:13 PM UTC
You cannot create and modify a user parameter anyway.
Try creating a Python global variable in the PythonCaller and referring it directly in Shutdown Script, as ​@david_r mentioned.
Note that you will have to write the codes in the input method to assign a featrue attribute value to the global variable. See also the screenshots below.
[Addition] Oh, your example was a function. Of course, this function works too.
__alex__
  • Jul 11, 2025 9:20 PM UTC
import fme
import fmeobjects
    # global _x
    # _x = "fantastic"
    # this guy:
Thanks ​@david_r  and ​@takashi - that’s a really interesting approach.
The code I posted worked in FME Form 2024, as long as I used a parameter called _x of type Text, and assigned a string value to it from the PythonCaller. I was then able to access that value in the shutdown script without any issues.
However, when I tried assigning a list to _x, it threw a custom exception.
I’ll take your warning into account and avoid assigning values to macros from the PythonCaller. Using a simple global variable is also cleaner. It didn’t work for me when I tried to run it only with the global keyword, but I’ll give it another try now when I have a complete solution by Takashi.
