Obj to gltf conversion issues in latest fme
  • Sep 5, 2019 4:57 AM UTC
  • 6 replies
  • 158 views
Hi
Im unable to convert Obj to gltf in the latest update.I have downloaded some sample obj files from this site.
Im always getting this warning Geometries which cannot be converted to a triangulated mesh will not be written.
How to avoid this and achieve the conversion.
In the previous versions of fme im able to convert these obj files but now its not working. What is the reason.Some sample file https://free3d.com/3d-model/alien-ship-from-battleship-37326.html which i used.Most of the obj im converting getting this error.Previous version this issue was not there.
FME version : FME(R) 2019.1.0.0 (20190710 - Build 19608 - WIN64 ).
OS : windows 10.
daveatsafe
Forum|alt.badge.img+24
  • Sep 5, 2019 9:57 PM UTC
Hi @san,
The OBJ file in question has a mesh with parts that have bad geometries, which is what is preventing it from writing to glTF.
I am attaching a workspace that uses a GeometryCoercer to convert the OBJ mesh to a composite surface, then uses a GeometryValidator to fix the surfaces. The glTF writer will convert the fixed surface back to a mesh when it writes.
Fix_OBJ.fmw
  • Sep 6, 2019 4:04 AM UTC
Hi @san,
Fix_OBJ.fmw
Thank you so much for the reply dave. But I'm trying to create a automated environment to convert multiple obj files.So i tried creating one workspace and using it for all conversions.But sometimes its failing how to tackle this kind of issues.How can i create a workspace that can convert any obj file to glTF. I even tried using your workspace for conversions but it didnt worked.
But in previous fme version 2018.1.0.3 the conversion of the obj file was successful without any errors.It is failing in 2019 version.What could be the reason.
How can i create one single workspace that can convert any obj file to glTF without any Errors.
daveatsafe
  • Sep 9, 2019 4:43 PM UTC
Hi @san,
I get the same error from that file when I do the conversion in FME 2018.1 as well. Would you mind sending me the log file form the successful conversion, so that I can try to find the reason it succeeded?
  • Sep 11, 2019 5:09 AM UTC
Hi @san,
battleship.zipobj2gltffmesupport.zip
Actually i meant conversion of the other file i didn't attached.Please find in the attachments.I also kept the log files of both versions of fme. Old version the conversion is successful and in the new version it failed.
daveatsafe
  • Sep 11, 2019 4:38 PM UTC
Hi @san,
I see what you mean now. I have passed the problem file to our dev team. In the meantime, I am attaching an updated workspace that will fix this file as well.
  • Dec 27, 2019 4:43 PM UTC
hi, maybe you should try this free 3d models, vray materials, cad blocks
