Need help with scripted parameter. I want to be able to grab a file path, then modify it by adding double slash. My code runs in python ide but not in FME. Thanks for your help!
  • Jun 14, 2023 1:27 PM UTC
  • 124 views
fme
Forum|alt.badge.img+7
def add_double_slash(file_path):
  modified_path = ''
  for char in file_path:
    if char == '\\\\':
      modified_path += '\\\\\\\\'
    else:
      modified_path += char
  return modified_path
# Example usage
file_path = r'C:\\Users\\Username\\Documents\\file.txt'
modified_file_path = add_double_slash(file_path)
print(modified_file_path)
Best answer by david_r
I'm not quite sure I understand what you want, but if you want a scripted private parameter to add double backslashes to a public parameter containing a filename, you could use the following code in your Python scripted parameter:
import fme
file_path = fme.macroValues.get('FILE_PATH', '')
return file_path.replace('\\', '\\\\')
Be aware that there are no checks on whether FILE_PATH already contains double backslashes.
  • Jun 14, 2023 2:28 PM UTC
import fme
fme
  • Jun 14, 2023 3:03 PM UTC
import fme
@david_r​  Yes, i want to grab the file path from a public parameter(C:\Users\Username\Documents\file.txt'), modify it through the scripted parameter (Private) by adding double slashes C:\\Users\\Username\\Documents\\file.txt to be used as  value in the transformer PDF2TEXTREADER
  • Jun 14, 2023 3:29 PM UTC
@david_r​  Yes, i want to grab the file path from a public parameter(C:\\Users\\Username\\Documents\\file.txt'), modify it through the scripted parameter (Private) by adding double slashes C:\\\\Users\\\\Username\\\\Documents\\\\file.txt to be used as value in the transformer PDF2TEXTREADER
You could also simply drop the Python code and use a ParameterFetcher to retrieve the path, then a StringReplacer to replace \\ with \\\\ before sending it to the PDF2TEXTREADER.
fme
  • Jun 14, 2023 4:08 PM UTC
Thank you, @david_r​ !
