For a job that has been working for years, it is now endlessly polling job status and returning awaiting worker. In Server, the last message you get is about the Socrata Write executing. In the desktop software you get more information and it reflects endless polling. Something has changed and I'm having trouble figuring out the cause. 2 of 24 of these (county specific) ran and the rest hung, and now even the two that ran initially will hang. It appears to be happening in the last step involving the Socrata Writer. This is the last log information, with the "Polling the job status: Awaiting worker" repeating endlessly. Other jobs that write to Socrata are still working. It isn't blanket failure on writing to Socrata. Any thoughts on cause or leads to investigate are welcome. Thanks
Socrata Writer: 0 features treated as points, 0 features coerced to point, 0 features with unsupported geometries written without geometry
Socrata Writer: Invoking Socrata DataSync with control file action 'Append'. Messages from the tool will be output below
Socrata Writer: Executing `""D:\Program Files\FME\jre\bin\java" -Xmx1g -jar "D:\Program Files\FME\plugins\socrata\datasync.jar" -ph true -sc "C:\Users\AACONR~1.SCH\AppData\Local\Temp\4\FME_1686308740400_540\control.json" -i 9xq5-z8s2 -c "C:\Users\AACONR~1.SCH\AppData\Local\Temp\4\FME_1686308740400_540\config.json" --userAgent "FME/2019.7.37.19608" -f "C:\Users\AACONR~1.SCH\AppData\Local\Temp\4\FME_1686308740400_540\TEMP.csv" 2>&1"'
Publishing TEMP.csv via delta-importer-2 over HTTP
Acquiring the previous signature or creating a null signature
Calculating the diff between the source file and previous signature
Chunking and posting the diff
Read 1024000 of 30500805 bytes of TEMP.csv
Uploading 3826941 bytes of the diff
Uploaded 3826941 bytes
Commiting the chunked diffs to apply the patch
We noticed in the details for the process  wait chain that the hung jobs appear to be waiting on a thread, whereas others that work are not. It isn't much detail to go off of and we suspect it is just another view on the endless polling action.
threadpolling
Hi @conrad.schaefer​
Sorry you ran into this issue while using the Socrata Writer! I found a related known issue (FMEENGINE-39441) where the Socrata Writer continues polling the web service until it has a success, but that response fails to come from Socrata. Since it's an error message from Socrata, it's worth investigating on that side to see if something might be blocking this process. However, if the issue is causing your jobs to run continuously, we should further investigate. I have a few troubleshooting questions to start:
  • What version and build of FME are you using, for both Desktop and Server applications?
  • If you hover over the Socrata Writer in your Navigator, what version is it? If it's older, update it.
  • How do you typically end the job?
  • How long does this job typically run for?
  • If you turn on Debug logging, is any additional error information logged?
Since there are a lot of moving parts here, I recommend filing a case with support. Please include the entire log file, the workspace, and any other relevant information in the case. Thank you!
Thank you @sanaeatsafe​ , very much.
I have enabled Debug and gotten a bit more information. For the update of one asset the log indicated "Polling the job status: Awaiting replication of dataset easset 4x4 xxxx-xxxx] while processing TEMP.csv"
Since your reply I have tried more troubleshooting tactics aimed at the Socrata side and I think it may be an issue on their platform. For example, the manual upsert of data using a csv gets stuck in a "creating columns" step (according to the web page messaging at least) so even that mechanism is failing to work. I have reached out to their support for assistance.
If they do not identify an issue I will move forward with your recommendations and log a support case with Safe.
Thank you again for replying with tips and thoughts.
