Is there a way to generate lines between each point and the nearest road centerline?
  • Mar 25, 2021 6:50 PM UTC
  • 104 views
gis_queen
I have 2 shapefiles:
  • roadway centerlines
  • house points
is there a way to generate lines between each point and the nearest road centerline?
Best answer by jdh
Use a NeighborFinder with the house as base and the roadway centerlines as candidate.
On the MatchedBase port use a VertexCreator in mode Add Point with the x/y values coming from _closest_candidate_x/y
jdh
Forum|alt.badge.img+41
  • Mar 25, 2021 7:10 PM UTC
gis_queen
  • Mar 25, 2021 7:40 PM UTC
Wow, thanks so much! That definitely got it going but it's not drawing all the way back to the road. Did I maybe miss something?candidate1houses1
jdh
  • Mar 25, 2021 8:55 PM UTC
you set the wrong attribute on the y_value
gis_queen
  • Mar 25, 2021 9:30 PM UTC
oops, that's embarrassing. Thanks again for coaching me through this. Things look great now!
