How to write outputs with different formats (CSAR, XML, GML) (with a different extension) to one Zip file ?
  • Aug 16, 2022 1:06 PM UTC
  • 103 views
I want to write a CSAR raster, metadata (.XML) and an additional layer (.GML) to one zipped file. If I add folder.zip to the path the first files are being overwritten and dataset fanout does seem like a way
to split an existing output into multiple file extension to be zipped. Both options are not giving the desired result.
evieatsafe
Forum|alt.badge.img+28
  • Sep 6, 2022 9:35 PM UTC
Hi @yasminvb​ thanks for your question, could you provide a sample workspace and screenshots of this issue? Thanks!
  • Sep 12, 2022 11:56 AM UTC
Thank you! We solved it by running the workspace in one go instead of running it part by part. I think we will use the FME server in the future to be able to combine all data.
