How to upload SSL certificates on my FME server to allow the connection to Kafka with HTTPS?
Hi @misazab95​
Does it work if you upload your certificate to the resources folder?
Screen Shot 2021-04-13 at 2.24.34 PMYou can get the file path by opening the file properties:
Screen Shot 2021-04-13 at 2.24.41 PMPaste the system path into the KafkaConnector:
Screen Shot 2021-04-13 at 2.25.05 PM
Publish the workspace to FME Server and test it
  • April 13, 2021
jlutherthomas wrote:
Hi @misazab95​
Can i upload it with the API to?
You could try this: https://docs.safe.com/fme/html/FME_REST/apidoc/v3/index.html#!/resources/add_post_14
  • April 13, 2021
Ok, Thank you 😀 😊
