How to sum up values separated by a comma?
grayson
Forum|alt.badge.img+3
I'm an FME newbi. Feel like it's something very basic but couldn't come up with a solution on my own.
What I want to achieve is to get 80% of the value from column B to column A, but some of the features have multiple values separated by a comma, soo they come out as NULL.
I went through previously asked questions but couldn't find anything. Appreciate any help!
Zrzut ekranu 2023-05-02 172731
Best answer by dustin
Split the attribute at the comma with an AttributeSplitter, which will put the values into a list. Then use a ListSummer to add up the values from the list.image
dustin
Forum|alt.badge.img+30
  • May 2, 2023
grayson
  • May 3, 2023
well, it helped! Thanks a lot!
I tried to use Attribute splitter before, when working on something different, but without ListSummer. It didn't make any sense back then. Thanks again!
