How to save the Attribute definition in a csv ?
  • Feb 9, 2022 1:52 PM UTC
  • 185 views
fmebenching
Hi ! I wanted to know if there was a way to save the attributes definition (Name, type and width) in to a CSV.
Thanks for the help !
Best answer by markatsafe
Thanks for the answer ! that's a very straight forward transformer to do what i want, but I only have access to the 2020 version of FME and I can't find the transformer so I guess it's only for the newer versions of the software ?
You can use the Schema (any format) instead, or the FeatureReader <schema> port
chrisatsafe
Hi @fmenewbie_jr​ ,
Check out the new SchemaScanner transformer - it'll tell you everything you need. Here is an example with an Excel file where it provides the name, data type (<width>, <precision if applicable>). A schema feature will store all of this in a list which you can explode with a ListExploder. Then you can parse/format as needed for your desired output.
imageIf you are using an older release of FME, you can still get this information with a schema feature using either the Schema Reader or a schema feature from the FeatureReader.
fmebenching
  • Feb 9, 2022 8:05 PM UTC
Hi @fmenewbie_jr​ ,
  • Feb 9, 2022 9:07 PM UTC
fmebenching
  • Feb 10, 2022 1:35 PM UTC
I combined the two answers and used the FeatureReader with a ListExploder and it worked ! thanks for the help !!
