How to extract workspace parameters in bulk from .fmw scripts?
  • Dec 4, 2023 3:22 PM UTC
  • 235 views
dragonsam
I am doing an inventarisation of all our scripts. Each script has the workspace parameters completed. This information is ideal for the inventary. I have found a way to do this adding each .fmw script individually, but this is very time consuming so I am looking for a way to do so in bulk.
I tried to use Directory reader to initially find all the .fmw scripts in a particular path, and this works, however I do not find a way now from this list how to extract info from inside the various files. I tried the FeatureReader transformer as I used this before to extract DWG files in bulk, but that does not seem to work for .fmw files.
Best answer by david_r
You're on the right track. In the FeatureReader, use the FMW reader. Check the output from the UserParameters feature type, see https://docs.safe.com/fme/html/FME-Form-Documentation/FME-ReadersWriters/fmw/Feature_Representation.htm
dustin
Forum|alt.badge.img+36
  • Dec 4, 2023 3:28 PM UTC
It sounds like you need a Parent-Child workspace setup using the WorkspaceRunner. In the first workspace (parent), you will use the Directory and File Pathnames Reader to create a feature for each of the .fmw files. Those will be fed into the WorkspaceRunner, where it will be set to the second workspace (child) that is running your script.
  • Dec 4, 2023 3:59 PM UTC
dragonsam
  • Dec 5, 2023 3:08 PM UTC
Thank you, that was exactly what I was looking for. It works now.
krystalp
  • Jul 9, 2024 9:23 PM UTC
I was hoping to use the FMW Reader to see what version of Python was set in the Workspace Parameters but it doesn’t seem to capture that.  Any other suggestions?
