How can I use variable database connections in fme server depending on the specific user parameter input? This works fine in desktop but not with server.
  • Oct 27, 2022 12:08 PM UTC
  • 5 replies
  • 115 views
I have a workspace where I use the oracle database connections as a variable. This works fine. When a runs the workspace a published parameter determines which connection is used.
But when I publish this on fme server. I get an authorisation failure:
FME Server error: `Unauthorized request by user due to lack of proper permissions for connection: **@**. Please see: http://fme.ly/zn8'
Connections in fme server are available as in the variable.
Best answer by ejmpost
Found the solution in token management. Did not realize the app is using deparate permissions.
  • Oct 27, 2022 12:14 PM UTC
The error message indicates that the database connection hasn't been shared with the user running the workspace. Is that possible?
  • Oct 31, 2022 7:41 AM UTC
I was looking into that and found that it works when I enter the connection manually. But only when running the workspace directly from fme server. When I launch it with an app I get the same error. So is there something different when using a fme server app?
  • Oct 31, 2022 8:01 AM UTC
Look in the FME job log after being executed by the automation, and search for "FME_SECURITY_USER" and "FME_SERVER_RUNTIME_USER_ID". The username specified for this parameter must have explicit access to the database connection.
  • Oct 31, 2022 8:15 AM UTC
  • Oct 31, 2022 8:18 AM UTC
Found it. Thanks for your replies.
