Hello, is there a possibility with FME to read in an excel "xml spreadsheet 2003"? Thank you very much. Greetings Ebi
ebiku
 The  excel "xml spreadsheet 2003" based on SpreadsheetML (XML schema for Microsoft Office Excel 2003)
Forum|alt.badge.img+49
Have you tried it?
ebiku
  • February 1, 2023
I tried the XLSXR Reader. It doesn't work (what a suprise 😬 )
debbiatsafe
Forum|alt.badge.img+20
  • February 2, 2023
Hello @ebiku​
If the XML Spreadsheet 2003 file is based on XML (likely given the name), it should be possible to work the file as XML within FME.
You would likely have to correctly configure the XML reader and use attribute transformers to extract the values required. Here is an article on XML reader configuration with examples in case it helps.
steveatsafe
Forum|alt.badge.img+12
@ebiku​  I'm following up on this question. Were you able to have success reading this XML file format?
