FME Weekly Quiz: Can you outscore Stephanie Warner (June 2020-1)
mark2atsafe
Forum|alt.badge.img+44
Hello everyone,
For the FME Quiz this week I've put you up against my colleague Stephanie Warner.
Officially, Stephanie's job title is Marketing Coordinator, but you may recognize her most from organizing and moderating all our webinars at Safe, occasionally taking to the screen during the start or end of each event. I believe she's also responsible for creating the slide layouts for presentations, and all sorts of marketing collateral like that.
Stephanie claims her "FME IQ" is fairly low, but then that's what all of the marketing team claims, and yet they're top of the league in quiz results per department at Safe!
So test yourself against her here: https://demos-safe-software.fmecloud.com/fmeserver/apps/FMEQuiz
Incidentally, I've been asked if it's OK to take the quiz before I post it here. Yes, that should (normally) be fine. If you see the quiz is available then it just means that the Safer hasn't yet taken the quiz. I've opened it up for them, but not alerted you to it. So your results are recorded correctly, but you just won't know if you beat the Safer or not.
erik_jan
Forum|alt.badge.img+17
  • June 1, 2020
Yes, my first 6 out of 6 as far as I can remember!
mark2atsafe
  • June 1, 2020
Yay! Well done. It's the only perfect score so far.
I feel pretty good with my 5 out of 6. I could not for the life of me figure out the bot one.
Forum|alt.badge.img+49
5/6, I suspect I may have the bot one wrong too...
mark2atsafe
  • June 2, 2020
Actually, you got that one right!
