FME Desktop 2022: How to identify gaps between the polygons of same layer?
jamal
Forum|alt.badge.img+5
In the screenshot below, I have a layer that has 6 polygons. It’s easy to identify the overlaps between these polygons with the “AreaOnArea” tool but how gaps can be identified?
Clip_151
Best answer by geomancer
geomancer wrote:
Use a Dissolver instead of an Aggregator.
Gaps_and_overlaps
Take the results of the Outershell port of the DonutHoleExtractor, buffer by your favorite tolerance, perform an AreaOnAreaOverlayer, keep only the features with _overlaps >= 2, clip with the results of the Outershell port of the DonutHoleExtractor, and keep only the results of the Outside port.
Gaps_and_overlaps_2
danilo_fme
Forum|alt.badge.img+41
  • March 4, 2022
Hi @jamal​
With the attribute _overlaps is not good for you?
Overlaps
Thanks in Advance,
Danilo
mark2atsafe
Forum|alt.badge.img+43
Perhaps you can try the AreaGapAndOverlapCleaner transformer?
jamal
  • March 4, 2022
1)    The “AreaOnAreaOverlayer” tool doesn’t catch the gaps
2)    The “AreaGapAndOverlapCleaner” tool doesn’t identify the gaps\\overlap but rather resolve
Is there a tool that can identify the gaps\\overlaps?
Clip_162
Clip_163
Clip_164
hkingsbury
Forum|alt.badge.img+51
  • March 7, 2022
If you're looking for gaps, use the AreaGapAndOverlapCleaner, then use the repaired output as clippees and your original geom as the clipper. The Outside port will have the gap geometries
image.pngimage
jamal
  • March 8, 2022
Thank you for the help.
My issue here is to identify the gaps and overlaps BUT not to resolve them
Of course, overlaps can be easily identified, but i couldn't figure out who to do so for gaps.
is this still be possible?
Sample data and workbench are attached
Clip_204
Clip_205
Clip_206
geomancer
Forum|alt.badge.img+47
  • March 8, 2022
Take a look at the DonutHoleExtractor.
jamal
  • March 8, 2022
I used the "aggregator" tool (based on the autocad_hatch field) then the "DonutHoleExtractor" but fails to identify the gaps
Clip_208
juanmahere
Forum|alt.badge.img+11
  • March 8, 2022
Hi @jamal​ ,
Not sure if you solved this question. I've tried some sort of solution, and here is my output:
gaps identified
In total there are up to 20 gaps between your 6 geometries.
Here is the workflow:
FME workbench
Let me know if you have any doubts,
Keep talking,
Juanma,
geomancer
  • March 8, 2022
Clip_208
Gaps_and_overlaps
jamal
  • March 8, 2022
Gaps_and_overlaps
That's great. However, in my case, gaps need to be indentified between all polygons considering a certain tolerance (say 55 meter).
Then how to catch the indicate gab below as the tolerance is less than 55 meter
The data is attached
Clip_212
Clip_213
geomancer
  • March 8, 2022
Gaps_and_overlaps
Gaps_and_overlaps_2
hkingsbury
  • March 8, 2022
Clip_204
Clip_205
Clip_206
The solution I posted outputs the gaps on the Outside port on the Clipper
jamal
  • March 8, 2022
Thank you very much geomancer for the help. It works perfectly
My thanks are extended to Juanma for the other approach provided
Clip_218
Clip_219
jamal
  • March 8, 2022
I applied it on the k22.dwg and it works fine
Clip_220
jamal
  • March 9, 2022
Many thanks hkingsbury for the useful input
