FME Desktop 2020.0.0.0: The “clipper” tool fails to proceed and gets stuck,
  • December 14, 2021
  • 16 views
jamal
Forum|alt.badge.img+5
I couldn’t figure out why the “clipper” tool fails to proceed and gets stuck,
What could be the issue here?
The workbench and data are attached
Clip_1338
Clip_1339
Clip_1336
Clip_1337
Best answer by hkingsbury
The vast majority of your geometries are Arcs, these are represented as a mathematical equation rather than a series of vertices.
After the geometry validator, add an ArcStroker to convert the arcs into lines. The process then runs in ~6 seconds
hkingsbury
Forum|alt.badge.img+54
  • December 14, 2021
jamal
  • December 17, 2021
It works like a charm.
However, I couldn’t figure out what the ArcStroker has fixed!
Clip_1344
hkingsbury
  • December 18, 2021
Clip_1344
The ArcStroker inperpolates vertices along the arc convert the true curve into a standard line
http://docs.safe.com/fme/html/FME_Desktop_Documentation/FME_Transformers/Transformers/arcstroker.htm
