FME cannot handle mixed-Z node in a single feature ?
lifalin2016
Forum|alt.badge.img+29
Hi all.
An I correct in assuming, that FME cannot handle non-point geometries, i.e. with multiple nodes, when some nodes have Z values, and some don't ?
I'm seeing that GeometryReplacer adds dummy Z values (0) where they're missing when importing from WKT og GeoJSON.
Is this a problem with the transformer only, or a more general problem with the handling of Z values ?
In a system we're running on FME Server, I need to replace any missing Z values with an official fixed value: -99. This is done using the 3DForcer. But if I can't control missing Z values during import, things are very problematic.
I made a small test workspace, and ran it in 2020.2 and 2022.2, and both exhibited the same behaviour.
Cheers
Best answer by ebygomm
It does seem to handle them in the native readers and writers. If I read a table with that geometry in this is what it looks likeimageIf I then write that geometry back into a MS SQL table that missing z value is respected
Forum|alt.badge.img+31
  • March 28, 2023
lifalin2016
  • March 30, 2023
Interesting, so the problem lies with the transformer then.
To circumvent this buggy behaviour, I've opted to insert the official dummy Z (-99) instead of just removing them. It's not optimal, but this way I can get things working.
  • March 30, 2023
Did you try using -nan? If you are writing back to a MS SQL database this should give the result you expected.
i.e. if you put the following through a geometry replacer you will get a geometry in MS SQL without a z value for the first coordinate
LINESTRING (571385.6196 6138491.615 -nan,571392.3857 6138491.1588 109.433,571398.7318 6138488.917 109.209)
lifalin2016
  • March 30, 2023
No. As I wrote, I opted for replacing faulty Z values instead of removing them. If I get more time later, I may look into it, but not now.
