FME 2020: How to select polygons (areas) that contain more than point?
  • Jan 29, 2021 6:46 AM UTC
  • 114 views
jamal
Forum|alt.badge.img+5
FME 2020: How to select polygons (areas) that contain more than one point?
I couldn’t figure out how to select polygons (areas) that contain more than one point. For example, in the screenshot below, I got just two polygons that contain more than one point. How to get them identified and selected?
Clip_283
Best answer by nielsgerrits
One way to do this is to use a PointOnAreaOverlayer, Area outputport, Tester _overlaps > 1.
You can also use a SpatialRelator and test for _related_candidates > 1.
nielsgerrits
Forum|alt.badge.img+67
  • Jan 29, 2021 7:05 AM UTC
jamal
  • Jan 29, 2021 7:37 AM UTC
Thank you very much nielsgerrits for the help. It works fine
Clip_288
Clip_289
