Feature count has disappeared (FME 2020.1)
  • Dec 15, 2020 1:49 PM UTC
  • 158 views
I have been using FME 2020.1 for about 6 months now and suddenly today the Feature Count numbers disappeared while running a workbench (and after the workbench finished running). The Feature Counts appear if I run the workbench in Feature Cache mode, but not in normal mode. I'm not sure if I unknowingly changed a setting but I didn't think I did.
I am using version FME(R) 2020.1.1.1 (20200817 - Build 20614 - WIN64).
Has anyone else encountered this problem?
Best answer by aquamarine
I've found that I can turn on the Feature Counts in 'Tools' --> 'FME Options' --> 'Translation' --> 'Display Feature Counts' but not sure how I turned it off to start with as I didn't go into that dialogue box at all...
  • Dec 15, 2020 4:03 PM UTC
hkingsbury
Forum|alt.badge.img+73
  • Dec 15, 2020 7:11 PM UTC
To add to this, FME Stores it's configuration in the registry. If you have multiple versions of FME installed this means they all use the same settings.
For example, if you enable Run with Feature Inspection in 2020.0, but also have 2017.1 installed, Run With Full Inspection will be enabled on 2017
