Exiting table feed no records and out is null
  • Oct 3, 2022 4:50 PM UTC
  • 37 views
asadamjad
Participant
Forum|alt.badge.img+12
I trying to insert the record on the Exiting table but it's giving me null values with successfully
image" data-fileid="0694Q00000LGK5uQAHimage
carmijo
  • Oct 3, 2022 4:55 PM UTC
Hi @asadamjad, what writer type are you using? i would start by checking the writers user attributes tab and use the automatic setting if possible for your use case
image--
If i've provided something helpful, please upvote the comment. If i've provided a solution, please mark it as 'Best Answer'. This helps the community find solutions when your question is referenced.
If I didn't provide a solution, please let me know if I can help further. Thanks! 🙂
asadamjad
Participant
  • Participant
  • Oct 3, 2022 6:02 PM UTC
This is the Workspace ....
carmijo
  • Oct 3, 2022 6:09 PM UTC
I think more information about the problem would help. I was expecting to see a writer but I'm not seeing any in the workspace
asadamjad
Participant
  • Participant
  • Oct 4, 2022 9:21 AM UTC
please check workspce
