Error running translation when trying to aggregate CAD files grouped by filename.
  • Mar 31, 2022 4:01 PM UTC
  • 80 views
lorenrouth
Forum|alt.badge.img+9
I am trying to do something that seems completely benign, which is to aggregate CAD file features by their filename. Instead, it gives a generic error after processing the 6 dwgs selected. Please see the attached log file, which was created with debug on. Any ideas? Is this something you should not do in general? Using just a REAL DWG Reader and the Aggregator.
Any insight is appreciated.
daveatsafe
Forum|alt.badge.img+24
  • Mar 31, 2022 9:22 PM UTC
Hi @lorenrouth​,
Please try turning off Run - Enable Feature Caching, and see if you get the same error.
lorenrouth
  • Mar 31, 2022 9:29 PM UTC
Hi @daveatsafe​
OK it worked. I guess it was about clearing the cache? Was able to run it with feature caching re-enabled.
Thanks!
