create group from numeric value
  • May 18, 2022 11:05 AM UTC
  • 134 views
alc33
Forum|alt.badge.img+14
Hi !
I have an xls file with 2 columns. One contains a code and the other contains numerics values.
I would like to create an attribute that group my data when there are a break on the values and group by code. For example :
code value
a 1 => group 1
a 2 => group 1
a 3 => group 1
a 10 => group 2
a 11 => group 2
b 1 => group 3
b 2 => group 3
I saw "AttributeRangeMapper" but I have to indicate the bounds. In my case I would like that the bounds are create automatically because my datas change every time.
My values can be integer or decimal.
Thanks !
Best answer by geomancer
Use the 'Adjacent Feature Attributes' option of the AttributeManager. When 'Code' does not change, and 'Value' increases by 1, use the current group number. In all other cases increase the group number by 1.
Grouping
geomancer
Forum|alt.badge.img+71
  • May 18, 2022 11:54 AM UTC
Grouping
alc33
  • May 18, 2022 1:23 PM UTC
Great!
I didn't know this option.
Thank you! It works very well!
geomancer
  • May 18, 2022 1:52 PM UTC
That's what I like most about this community: is a great place to learn something new about FME. Every day!
