coordinate Adjustment based on the accuracy
  • Sep 5, 2020 1:15 PM UTC
  • 65 views
boubcher
Forum|alt.badge.img+11
hello there a mobile app to collect data from the field and we are getting coordinate value and accuracy value
the accuracy is changing for each location
is there a way we could adjust the coordinates based on the accuracy
long: 42.725667797161
lat : 18.35510516986
accuracy 5.22930621796
in other terms what will be the coordinate value if the accuracy is close to 0
Thanks
  • Sep 7, 2020 7:41 AM UTC
I tend to interpret accuracy as a theoretical circle around the given point, indicating that the actual point probably lies somewhere within that circle.
Unless accuracy means something else in this context, I'm not sure how you imagine using the accuracy value to extrapolate the "real" point?
Forum|alt.badge.img+63
So what does that accuracy of 5.229 etc mean?
Realistically speaking, with lat/lon values collected by a mobile app that amount of decimal places is completely unnecessary. 12 decimal places in degrees puts you in the nanometer range, "atomic scale". Using a CoordinateRounder to bring that back to manageable values.
This is something I have taped to my monitor to keep things in check
cheatsheet
boubcher
  • Sep 8, 2020 4:58 PM UTC
cheatsheet
@Hans van der Maarel​
if I understand you well we need to round those coordinate in order to get a realistic location?
Let me put you in context
the mobile used to collect info from gas station on the road
each station will have some services around it such as restaurant play area ..ext
du to the accuracy of the GPS reader some time we getting services close to B but in reality its close to Station A
we did use a buffer for each station , but we still have some the same issue as described
we though using with the accuracy value we could adjust the coordinate
Any thoughts?
