Convert string with binary value to a IEEE754 Float.
  • December 9, 2020
  • 7 replies
  • 320 views
nielsgerrits
Forum|alt.badge.img+54
I try to convert the binary value
01000000 10001010 10111011 10001100
to the value 4.33.
Also see the example:
exampleReproducable on this site:
http://binaryconvert.com/result_float.html?hexadecimal=408ABB8C
Is this doable in FME? And how?
Thanks!
Best answer by ebygomm
If you don't mind python, struct is a standard library I think
import fme
import fmeobjects
import struct
def processFeature(feature):
    binary = feature.getAttribute('value').replace(" ","")
    float = struct.unpack('f', struct.pack('I', int(binary,2)))[0]
    feature.setAttribute("float",float)
  • December 9, 2020
I think a few lines of Python is justified here, e.g.
import struct
flt = '01000000 10001010 10111011 10001100'
f = int(flt.replace(' '''), 2)  # Remove spaces
print(struct.unpack('f'struct.pack('I', f))[0])
Result:
4.335393905639648
It should be fairly easy to incorporate into a PythonCaller.
Forum|alt.badge.img+38
  • December 9, 2020
import fme
import fmeobjects
import struct
nielsgerrits
import struct
Result:
4.335393905639648
Thanks for the quick reply!
nielsgerrits
import fme
import fmeobjects
import struct
Thanks for the working piece! Really appreciate it.
nielsgerrits
  • December 11, 2020
import fme
import fmeobjects
import struct
Thanks again for this @ebygomm​ it works great. Providing a working example is really fantastic for people like me. I always have a really hard time to get anything Python related working, but tweaking something existing, what works, is doable.
I believe combining FME and Python will return far better solutions then FME only.  I would love to do this more, but somehow learning it really gives me a struggle.
Note: I don't have a programming background. And I think a lot FME users are in the same boat, else they would have fixed most of their issues using Python.
  • December 11, 2020
My python knowledge is gained almost entirely from reading these boards. I've never used python outside of FME! I'd avoided pythoncallers completely until I had an issue that was worth the pay off in time spent v timesaved.
  • December 11, 2020
Fortunately there is an enormeous amount of Python tutorials out there, most of them free.
For a general overview of teaching resources: https://wiki.python.org/moin/BeginnersGuide/Programmers
Step-by-step tutorial for beginners: https://python3.guide/
It's well worth the investment if you regularly work with non-trivial issues, in my opinion. Both within and without FME.
