Compare two strings and output the matching parts and count of parts that matched.
  • Oct 14, 2020 7:23 PM UTC
  • 404 views
Trying to compare two columns that have strings concatenated by ' | ' and look like this:
COL A
abc | def | ghi
COL B
abc | xyz
Desired result:
COL C that contains the matching part of both strings.
In this case result should be: abc
COL D containing the count of matched parts of the string.
In this case, result should be: 1
Would appreciate your response.
itsmatt
Forum|alt.badge.img+48
  • Oct 14, 2020 7:42 PM UTC
I think if you use a StingSearcher on COL A with COL B ​as the reg-ex to match and set to match all and create a list. This should give you the number of matches (COL D) as well as a list full of matches. Next use a ListConcatonator to squash the list into a single attribute (COL C) you can specify the delimiter for the attribute e.g., |
Let us know how you get on​
  • Oct 14, 2020 7:55 PM UTC
Thanks for your reply. So, I tried the StringSearcher but it only outputs the first match. How do I change it to match all? And I'm still not sure how to get number of matches from this transformer.
itsmatt
  • Oct 14, 2020 8:02 PM UTC
You will have to specify a list name. It will still output the first matched as attribute but there should also be a list attribute generated with matches. If the number of matches is not given you can use a listElementCounter to get the number​
