Compare two lists with PythonCaller
  • Nov 17, 2020 8:41 PM UTC
  • 132 views
dhaulagiri
Forum|alt.badge.img+4
Hello,
I'm working on a French address table. A column contains a string with the abbreviated street type and street name, e.g. "AV DES CHAMPS-ELYSEES". I divided it and I built a list with its elements: AV, DES, CHAMPS-ELYSEES
I now need to know if the first item in the list is a correct street type. For that, I have to compare it with about 200 values of a reference file, also stored in a list: AV, BD, CHE, IMP...
I think I have to use PythonCaller but I don't know how to go about it. Can you help me?
Regards,
Nicolas
Best answer by dhaulagiri
Great!
Forum|alt.badge.img+54
  • Nov 17, 2020 9:23 PM UTC
I don't think you need to use a PythonCaller for this. If you merge your list onto each feature, you can then use a listsearcher
Capture
dhaulagiri
  • Nov 17, 2020 10:13 PM UTC
Great!
