Clip LAS with Shapefile
  • Mar 17, 2021 1:33 PM UTC
  • 312 views
I'm working with relatively large LAS files and only needing small portions at a time. Is it possible to use a Shapefile to "trim" the excess points before transformation?
Best answer by redgeographics
Yes, that should be possible. Either through a Clipper or by using a feature from the Shapefile as the initiator for a FeatureReader.
Forum|alt.badge.img+63
itsmatt
Forum|alt.badge.img+48
  • Mar 18, 2021 3:04 PM UTC
Yeah, using a the shapefile as the filter in a FeatureReader is a good option here.
