calculate Perpendicular distance between road centerline to property polygon
  • Aug 2, 2022 9:55 AM UTC
  • 10 replies
  • 294 views
f.kemminje
Forum|alt.badge.img+11
I have a road center line and private properties beside(left and right) to road center line.
I want to find out the distance between the road centerline and private properties (perpendicular to the road centerline)
both the sides(left and right) for every kilometer.
  • Generate points along the road centerline for each kilometer
  • Calculate perpendicular distance from a point to private property polygons(left and right)tosafe_pri
  • Add attribute left1=min distance (left property polygon and right1=min distance to private property right side
Best answer by nielsgerrits
@nielsgerrits​  I tried neighbor finder But it did not help in this scenario. Because I need perpendicular property to the road centerline
I still think you should do it the other way around, using buildings as Bases and centerlines as Candidates.
But if you want to do it this way you can generate the interval you need using a densifier and a chopper. Then create perpendicular lines using the 2DVectorCalculator from the Hub. Then clip away the parts you do not need using the buildings and keep the parts touching the centerline.2022-08-02_15h25_37
nielsgerrits
Forum|alt.badge.img+67
One way to do this is to use the NeighborFinder. Chop the property area's to points and find the two closest points to the centerline.
f.kemminje
  • Aug 2, 2022 10:16 AM UTC
nielsgerrits
I think it works because the closest distance from the building to the centerline has to be perpendicular? Something like attached workspace? The only time it is not perpendicular is when the centerline is shorter than the building?
f.kemminje
  • Aug 2, 2022 11:27 AM UTC
Hi Capturesafe@nielsgerrits​ Thanks for the quick response and workspace. but my case is different, the surveyor goes to
each point(for ex: every mile interval) and checks what is the perpendicular property and how far it is from the road. neighbor finder catches the nearest property not the perpendicular one.
And I don't need distance for each property(need for interval points)
The attached image will give you a clarity
nielsgerrits
f.kemminje
  • Aug 3, 2022 4:23 PM UTC
@nielsgerrits​ Thank You very much.
nielsgerrits
Cheers :)
ladisrikanta123
Participant
@nielsgerrits​ Hey thanks for the neighbor finder method. But i am having some issue with feature merger transformer. Can you pls tell how it will work
ladisrikanta123
Participant
not able to merge road and building correctly
ladisrikanta123
Participant
@nielsgerrits​ Hey how to merge it if i have too many roads
