AttributeValidator NOT EQUAL to "VALUE "
  • Oct 30, 2020 5:06 PM UTC
  • 100 views
hlouie
Forum|alt.badge.img+16
Is there a way within in AttributeValidator Parameters -> Validation Rule -> Rule Configuration -> NOT EQUAL a value?
AttributeValidator
Best answer by ebygomm
I think this will work if you want to fail only exact matches, not contains as well
^(@Value(_projectid).+|(?!@Value(_projectid)).*)$
jdh
Forum|alt.badge.img+41
  • Oct 30, 2020 5:23 PM UTC
Could you use a 0 width negative lookahead in the regex?
Something like PROJECT_ID Contains Regex ^(?!@Value(_projectid))
It won't work if _projectid is found entirely within PROJECT_ID.
ex. projectid = 123 and PROJECT_ID= 1234
Forum|alt.badge.img+54
  • Oct 31, 2020 5:19 PM UTC
hkingsbury
Forum|alt.badge.img+73
  • Nov 1, 2020 6:38 PM UTC
Alternatively, could you replicate the logic in a tester?
