ARCGISONLINE MetadataOverwritter
  • Jul 13, 2023 6:13 AM UTC
  • 6 replies
  • 144 views
babar_ali99
Forum|alt.badge.img+3
I get the following error when I feed XML as an attribute from the XML updater. Reading in an XML file is no issue though.
This FME edition does not recognize the `' function. Please ensure that the current platform supports this function, the function name is spelled correctly, and that you have installed all required plug-ins
Best answer by siennaatsafe
@babar_ali99​ ,
The ArcGIS Online Metadata Overwriter wasn't originally designed to work with an attribute. However, I just updated so it should be able to handle an attribute. Try it out by upgrading the transformer. The image below shows how to do that from the navigater panel.2023-07-21_11-38-12
You'll have to set the XML Input paramete to Attribute, then select your attribute in the XML Source parameter. However, then it should work. Please let me know if you have any issues.
2023-07-21_11-47-25
siennaatsafe
Forum|alt.badge.img+12
Hi @babar_ali99​ ,
Would you mind providing the XML you are using and the version of FME?
babar_ali99
  • Jul 19, 2023 10:54 PM UTC
Hi @babar_ali99​ ,
HI Sienna,
I am using the following version
FME(R) 2022.1.2.0 (20220831 - Build 22627 - WIN64)
I can't provide the full XML because of sensitivity of the data. I can provide a portion of the XML below.
<?xml version="1.0" encoding="UTF-8"?>
<metadata xml:lang="en">
<Esri>
<CreaDate>20230609</CreaDate>
<CreaTime>13452300</CreaTime>
<ArcGISFormat>1.0</ArcGISFormat>
<SyncOnce>FALSE</SyncOnce>
<DataProperties>
<itemProps>
<imsContentType export="False">002</imsContentType>
<itemName Sync="FALSE">AustralianMarineParks_sort</itemName>
<nativeExtBox>
<westBL Sync="TRUE">70.717024</westBL>
<eastBL Sync="TRUE">170.366667</eastBL>
<southBL Sync="TRUE">-58.449470</southBL>
<northBL Sync="TRUE">-8.473407</northBL>
<exTypeCode Sync="TRUE">1</exTypeCode>
</nativeExtBox>
</itemProps>
<coordRef>
<type Sync="TRUE">Geographic</type>
<geogcsn Sync="TRUE">GCS_GDA_1994</geogcsn>
<csUnits Sync="TRUE">Angular Unit: Degree (0.017453)</csUnits>
<peXml Sync="TRUE">&lt;GeographicCoordinateSystem xsi:type='typens:GeographicCoordinateSystem' xmlns:xsi='http://www.w3.org/2001/XMLSchema-instance' xmlns:xs='http://www.w3.org/2001/XMLSchema' xmlns:typens='http://www.esri.com/schemas/ArcGIS/2.8.0'&gt;&lt;WKT&gt;GEOGCS[&amp;quot;GCS_GDA_1994&amp;quot;,DATUM[&amp;quot;D_GDA_1994&amp;quot;,SPHEROID[&amp;quot;GRS_1980&amp;quot;,6378137.0,298.257222101]],PRIMEM[&amp;quot;Greenwich&amp;quot;,0.0],UNIT[&amp;quot;Degree&amp;quot;,0.0174532925199433],AUTHORITY[&amp;quot;EPSG&amp;quot;,4283]]&lt;/WKT&gt;&lt;XOrigin&gt;-400&lt;/XOrigin&gt;&lt;YOrigin&gt;-400&lt;/YOrigin&gt;&lt;XYScale&gt;2226389776.5071998&lt;/XYScale&gt;&lt;ZOrigin&gt;0&lt;/ZOrigin&gt;&lt;ZScale&gt;1&lt;/ZScale&gt;&lt;MOrigin&gt;0&lt;/MOrigin&gt;&lt;MScale&gt;1&lt;/MScale&gt;&lt;XYTolerance&gt;8.9831530000000104e-10&lt;/XYTolerance&gt;&lt;ZTolerance&gt;0.001&lt;/ZTolerance&gt;&lt;MTolerance&gt;0.001&lt;/MTolerance&gt;&lt;HighPrecision&gt;true&lt;/HighPrecision&gt;&lt;LeftLongitude&gt;-180&lt;/LeftLongitude&gt;&lt;WKID&gt;4283&lt;/WKID&gt;&lt;LatestWKID&gt;4283&lt;/LatestWKID&gt;&lt;/GeographicCoordinateSystem&gt;</peXml>
</coordRef>
</DataProperties>
<scaleRange>
<minScale>150000000</minScale>
<maxScale>5000</maxScale>
</scaleRange>
<ArcGISProfile>ISO19139</ArcGISProfile>
<SyncDate>20230629</SyncDate>
<SyncTime>09102700</SyncTime>
<ModDate>20230629</ModDate>
<ModTime>09102700</ModTime>
</Esri>
<mdFileID>ecedecba-1a39-4933-868f-a96bb3cf4eed</mdFileID>
<mdLang>
<languageCode Sync="TRUE" value="eng"></languageCode>
<countryCode Sync="TRUE" value="AUS"></countryCode>
</mdLang>
<mdChar>
<CharSetCd Sync="TRUE" value="004"></CharSetCd>
</mdChar>
<mdHrLv>
<ScopeCd Sync="TRUE" value="005"></ScopeCd>
</mdHrLv>
<mdHrLvName Sync="TRUE">dataset</mdHrLvName>
<mdContact>
<rpOrgName>ABCD</rpOrgName>
siennaatsafe
Hi @babar_ali99 ,
Are you feeding an attribute directly into the ArcGISOnlineMetadataOverwriter?
It's expecting a file, could you try writing out the XML using the AttributeFileWriter, then set up the ArcGIS Online Metadata Overwriter to upload that file? 2023-07-20_09-15-102023-07-20_09-19-11 copy
If that isn't the issue would you mind creating a support case?
babar_ali99
  • Jul 21, 2023 6:39 AM UTC
Hi @babar_ali99 ,
Yes I am feeding the attribute directly just like you showed. and yes it works if I upload the XML. But I want to feed the attribute directly it directly.
siennaatsafe
  • Jul 21, 2023 6:47 PM UTC
@babar_ali99​ ,
2023-07-21_11-47-25
babar_ali99
  • Jul 24, 2023 5:22 AM UTC
@babar_ali99​ ,
2023-07-21_11-47-25
Thank you for updating the transformer. it worked :)
