A failure message appears in the buffer app if the input geodatabase has a feature class which has a different name of the one used in the buffer workbench
  • Apr 4, 2020 9:22 PM UTC
  • 55 views
lubna_najeh
A failure message appears in the buffer app if the input geodatabase has a feature class which has a different name of the one used in the buffer workbench.
Hi All,
I Couldn’t figure out if I can edit the reader on buffer workbench to make the buffer app take any geodatabase that contain any feature class regardless its name,
My app fails to run and return a failure message if the feature class name is not the same one I used in the workbench
Best,
Lubna
  • Apr 5, 2020 10:30 AM UTC
Hi @lubna_najeh, try checking the Merge Feature Type on in the reader feature type properties.
lubna_najeh
Thank you @takashi for your suggestion
Yes it works with me :)
Lubna
