OvertureMapsDataDownloader
  • Oct 3, 2024 2:00 PM UTC
  • 0 replies
  • 140 views
fmelizard
Forum|alt.badge.img+22
FME Hub user ardadurmus just uploaded a new transformer to the FME Hub.
OvertureMaps Downloader custom transformer allows FME users to directly access and download geospatial data from the OvertureMaps Foundation using DuckDB a high-performance SQL-based analytical database system. Runs with Executable file or command line system variable duckdb or duckdb.exe using System Caller. This transformer retrieving and storing overture map data in a local environment or temp folder that can be accesible during your process
enabling integration with FME workflows for further spatial analysis
transformation
or export into other formats. It's designed for users who need fast access to large-scale
open-source geospatial datasets in a seamless and efficient way.
Would you like to know more? Click here to find out more details!
