ImageIdentifier
  • Nov 14, 2024 10:00 PM UTC
  • 0 replies
  • 69 views
fmelizard
Forum|alt.badge.img+22
FME Hub user kailinatsafe just uploaded a new transformer to the FME Hub.
Description
The ImageIdentifier is designed for use with Ollamas' Llava 7B parameter model, leveraging its API endpoint for image classification. It is intended for use with JPEG and PNG image formats.
Installing Ollama and Llava 7B
This transformer will need an instance of Ollama running on a machine.
Ollama
Windows/Mac OS/Linux: https://ollama.com/download
Instructions can be found here: https://github.com/ollama/ollama?tab=readme-ov-file#ollama
Llava 7B Model
Instructions: https://ollama.com/library/llava:7b
Details
This transformer uses the URL from an Ollama instance and leverages Ollamas' Llava 7B API via its model. A prompt is used to make an HTTP GET Request. This is then returned to the user by attribute.
Photo by Robson Hatsukami Morgan on Unsplash
Would you like to know more? Click here to find out more details!
