We just installed FME Flow 2024.1.2.1 on a Windows machine and I published a workspace. Running the workspace immediately ends in:
Undefined macro `WORKSPACE_NAME' dereferenced in file `flow_testing\sqlserver_test_delete\sqlserver_test_delete.fmw'
The workspace was published from an ArcGIS Interoperability Workbench [FME(R) 2024.0.1.0 (20240328 - Build 24202 - WIN64)], but I tried the same from FME Form 2024.2. The result is the same.
The workspace is as simple as it gets. Just a reader and a writer, and the error appears independent if there is a name for the workspace set or not.
Can somebody please point me the right direction to solve the issue?
