writing to a gdb (api) a second time gives error
In a workspace I'm writing to a gdb (api), this works fine. If i use this workspace again it results in an error: FME can't write to the GDB. Parameter "overwrite existing database" = "YES"
MDB gives no troubles
nielsgerrits
Forum|alt.badge.img+56
FME version? I have a deja vu but can't find the previous topic. Can't reproduce this in 2018.0.0.2
Hi @kees_v
Could please elaborate more ans share screenshot for the workbench and the log file result .
check if the GDB node locked or not .
Forum|alt.badge.img+50
I seemed to have the issue when writing to a new GDB from time to time (with that parameter "overwrite existing database" set to yes)
oscard
Forum|alt.badge.img+21
  • May 24, 2018
Now and then I have an issue with the "Template File Geodatabse" parameter. I have to change its value from <Unused> to <not set> if I want the process to work:
