Writing spatial index on File geodatabase with a specific grid size
Best answer by mark2atsafe
I don't have ArcGIS installed right now, so I can't give you a screenshot (because w/o ArcGIS I can't create a Geodatabase Writer in FME) but you should open up the table definition in FME by clicking the cog icon on the Writer table objects. Then click the tab labelled Format Parameters. In there you should find some settings to control the grid size.
See this page for more info:
